Which Chuck Is Right For Me? | Woodturning Chucks
The purchase of a lathe by a prospective turner may be a considerable investment, but funding should also be allocated for other essential basic items such as a suitable chuck.
Chuck development at Axminster
Made by us in Axminster using the latest CNC production techniques, our world class chucks were not born overnight. They are the result of over three decades of experience in production and design. Our team of expert product designers and engineers here at Axminster Tools, produced one of the world's first four jaw, self-centering chucks for woodturners back in 1984. It wasn't long before the team explored all manner of different accessories for the chuck. They devised a style of mounting four quadrants of a profiled disc that we called jaws. These jaws are still, to this day, compatible with all the chucks we have made. It is important to us to ensure that the accessories you purchased yesterday, will still work with the chucks we make and sell today.
Over the years, much of the development of our chucks and jaws has come from the feedback and input of professional woodturners. And our design and engineering team continue to develop our lathe accessories to provide our customers with world class products.
The ever-expanding range of Axminster woodturning chucks now covers almost every type of work-holding requirement, from dolls’ house chair legs just a few millimetres in diameter to 60cm diameter bowls weighing 20kg or more. Precision made in high grade steel, the chucks and their associated accessories have been developed over the years, in many cases in discussion with our professional turning friends, to cover almost every eventuality likely to be encountered by the amateur or professional alike.
One of our guiding principles has always been to ensure that as many different operations as possible can be carried out without removing the chuck from the lathe. This approach, combined with the provision of multiple gripping diameters on most of the jaws, gives minimum outlay coupled with maximum flexibility of operation.
Apart from the junior chuck which utilises engineering end mill collets to hold small workpieces, all the Axminster chucks use the tried and tested scroll mechanism to control the jaw travel. This system provides the dual benefits of a nominal half inch of radial movement of each jaw in expansion and contraction and a security of grip onto the work which is unrivalled by any of the collet style chucks on the market. They are also supplied with a set of SafetyJaw accessory mounting jaws with rounded corners which minimise the chance of injury should your fingers get too close to the rotating chuck.
Axminster Essential SK88 Chuck
The 88mm steel chuck is the smallest chuck in the Axminster Woodturning range. It's light and compact design makes it suitable for a variety of lathes and is particularly suited to smaller models.
As with all the chucks in the Axminster Woodturning range, the SK88 is precision designed and manufactured from Axminster Tools HQ in Axminster, Devon, UK and is engineered using the latest in CNC technology.
The Essential SK88 Chuck, is a more compact version of our renowned stainless steel Clubman SK100 Chuck. Meticulously crafted with precision, the SK88 Chuck maintains the same design excellence that our customers have come to expect from the Clubman SK100 Chuck, but with a strategic engineering shift to EN1A steel. This cost effective alternative makes a perfect entry-level choice for beginners venturing into the art of woodturning.
The chuck package includes the basic tools needed for work holding on the lathe, and is ideal for beginners in woodturning. The package includes chuck body, faceplate ring, dovetail jaws and screw chuck (all available to buy separately).
Also available is a range of steel jaws compatible with the Essential SK88 Chuck, useful for holding a wide range of projects. The Essential SK88 Chuck can also be purchased as body only.
New
Axminster Woodturning Essential SK88 Chuck PackageFrom £169.98 £141.65 -
New
Axminster Woodturning Essential SK88 ChuckFrom £129.98 £108.32
Axminster Evolution Chucks
First drawn at a desk in Devon, the Evolution chuck has been machined and refined to make woodturning easier, accurate and more enjoyable. Our aim was to produce a chuck that was slim, keeping the weight of the work over the bearings.
We achieved maximum accuracy by threading the body of the chuck for perfect concentricity. We also wanted a chuck that would suit the jaws already owned by our customers. Our first prototypes were tested by some of the most well known names in the woodturning world.
Taking the best features of our Axminster chuck designs over the past 20 years, we have in our view the most superb woodturning chuck ever made - the Evolution SK114. We have introduced round the clock manufacturing at our production workshop in Axminster to keep pace with global demand.
Uniquely the Evolution body is made of stainless steel making it totally rustproof. Every millimetre of this chuck is made in the UK and assembled in Devon. All of the components are machined in our workshop giving us total control so that the chucks we produce are supreme in terms of longevity and quality. We even designed a box to have the perfect fit.
The Evolution is a revolution in chuck making and, we believe, it is the finest woodturning chuck ever made.
The Evolution SK100 Chuck is also available.
Axminster Clubman SK100 Chuck
The Clubman 100mm (4") stainless steel chuck body, including the thread, is a single piece, maximising concentricity and minimising vibration during use.
Using stainless steel allows closer tolerances during the manufacturing process as the chuck body no longer needs electro-plating, which can vary in thickness. These chucks are made by us in Axminster using the latest CNC production techniques.
All Axminster chucks are part of an excellent woodturning chuck system, just add a set of jaws or accessories from our extensive range to suit your needs. Supplied with our SafetyJaw accessory mounting jaws, which have rounded corners and a chuck key, they available in a range of thread options.
Axminster Woodturning Clubman SK100 ChuckFrom £199.98 £166.65
Axminster Woodturning Clubman SK100 Chuck PackageFrom £259.98 £216.65
Lathe Thread Information
The table below lists all the stock thread types which can be used when ordering any of the threaded items, such as chucks, chuck backplates, faceplates and screw chucks. If you are uncertain about which thread to specify please ring our Specialist Sales Team who will be pleased to help. They will need to know either the make of the lathe or the dimensions of the lathe spindle as shown in the diagram. The column heading numbers refer to the dimensions in the diagram as follows:
1. Register diameter.
2. Register length.
3. Thread diameter.
4. Combined length of thread and register.
5. Thread pitch, either threads per inch or thread pitch if metric.
Right hand threads
Thread size |
Lathe type |
1 |
2 |
3 |
4 |
5 |
T01 (3/4" x 16tpi) |
Carbatec, Coronet, Record |
3/4" |
3/16" |
3/4" |
11/16" |
16 |
T02 (1 1/2" x 6tpi) |
NV28-40, Supalathe, Harrison Graduate |
1.1/2" |
3/8" |
1.1/2" |
1.1/8" |
6 |
T03 (1" x 12tpi) |
Myford ML8 (Inboard), Turnstyler |
1.1/8" |
3/8" |
1" |
1" |
12 |
T04M (1" x 8tpi) |
Axminster AC240WL, AC305WL, AC370WL, AH-1218, AWSL/VSL, AWVSL 900/1000, Delta General 160, Sheppach DMS900 |
1" |
1/4" |
1" |
1.1/8" |
8 |
T06 (1 1/2" x 8tpi) |
Powermatic 90 |
1.1/2" |
3/8" |
1.1/2" |
1" |
8 |
T23 (1 1/4" x 8tpi) |
General 260, Powermatic 4224B/3520B |
1.1/4" |
1/8" |
1.1/4" |
1" |
8 |
T37 (33mm x 3.5mm) |
Minimax |
30mm |
18mm |
30mm |
40mm |
3.5mm |
T38 (33mm x 3.5mm) |
Axminster AC355WL, AT350WL, AT406WL, AT508WL, AT1416VS, AT1628VS, Jet 4224B, 2424, 3520B, 1642, 1442, 1015, 1221VS Killinger, Robust |
34mm |
16mm |
33mm |
30mm |
3.5mm |
T38R (33mm x 3.5mm) |
Extended body with reverse locking |
34mm |
16mm |
33mm |
30mm |
3.5mm |
T38W (33mm x 3.5mm) |
Woodfast |
33mm |
6mm |
33mm |
29mm |
3.5mm |
T38PRO* (33mm x 3.5mm) |
4224 Professional, 3520A |
33mm |
4mm |
33mm |
37mm |
3.5mm |
T38V (Special fitting) |
Vicmarc |
34mm |
16mm |
33mm |
30mm |
3.5mm |
VB36 (Special fitting) |
VB36 |
*Please measure register diameter (1) to ensure the correct fitting
Right hand / left hand threads
Thread size |
Lathe type |
1 |
2 |
3 |
4 |
5 |
T02RL (1 1/2" x 6tpi) |
Harrison Graduate and APTC Woodfast Lathes to suit both sides of the headstock |
1 1/2" |
3/8" |
1 1/2" |
1 1/8" |
6 |
Some care should be taken when buying a chuck as they’re machined with an internal thread which must match the spindle thread of the lathe it’s going to be used on. The chucks are also supplied with a set of precision ground accessory mounting jaws, machined with threaded holes which accept the Axminster range of lathe jaws.
Specialist Chucks
Apart from a standard chuck, it’s also desirable to have a way of initially mounting bowl blanks for the first rough turning. Although a faceplate (usually supplied with the lathe) can be used, it’s probably more convenient to use a Screw Chuck, which are available in a variety of different designs. Turning smaller items present their own difficulties, as tools and hands may become too close to the rotating parts of the lathe. One solution is to use an Axminster Junior Chuck (supplied with three collets). As knowledge and skill increase, more specialist and advanced equipment can be purchased, such as an Eccentric Spiralling Chuck which allows a range of eccentric and spiral stems to be produced.
Conclusion
The choice of a basic chuck is fairly straightforward and if funds allow, the Evolution SK114 is the obvious choice for larger lathes, with the SK88 for the smaller range of bench top lathes. For more advice on which chuck would suit your lathe and project contact our Specialist Sales Team on 03332 406406 or email sales@axminstertools.com.
Thanks for your info
I Have an Axminster AWSL 700241 woodturning lathe which is the best chuck and jaws for me
I have a Time Cub lathe with a 2 x 20 mm thread for a chuck. Can I use a 3/4 x 16 chuck from Axminster as a substitute. This size is mentioned in the Time description for the lathe.
Hi. I hope I sent a message yesterday regarding chuck sizes. I have a Tyme Cub lathe with a 2 x 20mm spindle. In the information is states that I can use a 3/4" x 16 TPI as an alternative. Can you let me know if this is correct. Thanks
Hello,
can you please advise the right chucks for Laguna REVO 1216?
I have Clark’s wood lathe model number cwl20rv part number 6500670 what is the best all round cluck for my lathe?
I recently started using lathes at my local Men's Shed. I am looking for a lathe suitable for pen turning and other small objects plus suitable chuck for these projects.
Would the evolution Chuck fit my old Nwl37-4 wood lathe
Hi there, yes our Evolution chuck would fit your NWL37-4 lathe. We recommend our latest SK100 Evolution Chuck for this lathe as it is much more lightweight but still encompasses all the same quality features as the SK114. We have had a look at what thread size you would need and you would need a 3/4" x 16 (part number 108568). I'll also include a link below with more information about our latest Evolution chuck!
https://knowledge.axminstertools.com/axminster-woodturning-evolution-special-edition-chuck/
