Flying the flag for British Made tools! This April, the team here at Axminster Tools are delighted to announce the launch of our brand new UJK Universal Dovetail Jig, designed, developed and made here on home soil. And we couldn’t be more proud to share this news with you.Â
With strong associations of quality and craft, and highly prized all over the world, British made products offer peace of mind that you’re investing in the best! With this in mind, we’re delighted to introduce the brand new UJK Universal Dovetail Jig, available to buy online, in store or over the phone.
1 jig, 6 joints
Straight out of the box, the UJK Universal Dovetail Jig gives you the possibility of producing six different joints, with unrivalled accuracy! Plus, it’s simple to use and easy to set up. View the jig and buy yours now.
Half blind dovetails
Used primarily for drawer box construction, half blind dovetails show the pins and tails on one side of the joint, while remaining completely invisible on the other. This makes them ideal for fastening drawer fronts to drawer sides.
Sliding dovetails
Frequently used in case work to connect shelves to side walls or between shelves in drawer dividers, sliding dovetails are deceptively simple joints to make using this jig.
Through dovetails
As one of the strongest joints available, the through dovetail joint has many benefits. These include being aesthetically pleasing thanks to its interlocking capabilities and resistance to being pulled apart. Furthermore, it offers a large gluing area, however the joint will also hold together even without glue!
Box/Finger joints
Ideal for making boxes and other solid cube shapes such as chests and carcases, precise comb or finger joints offer castellations with a very long glue line.
Groove/housing joints
Useful for adding partitions into cabinets and bookcases, a groove/housing joint is a strong and reliable joint that’s simple to make. A trench is cut into which the end of another component is inserted.
Corner dovetail rebates
Simple to construct, corner dovetail rebates enable mating parts to align easily and accurately. Furthermore, they create a larger gluing surface which provides a greater load-bearing capability than standard butt joints.
Why buy the UJK Universal Dovetail Jig?
Do more, work less, get better results. Learn more!
Made in the UK
The jig itself is made and developed right here at our state-of-the art manufacturing facility in Axminster, Devon. Straight out of the box it gives you the possibility of producing six different joints, with unrivalled accuracy. With “Made in Britain” status and approval, we take particular pride in the manufacture of our own products and this couldn’t be more true with our brand new UJK Universal Dovetail Jig.
From concept, design, material selection and sourcing through to prototype development, testing, quality control and finally, the production of the jig itself, when we say ‘Made in Britain’ we are able to truly mean it. Please note: the knobs and cutters are not made in the UK.
High quality materials
The base of the jig is robustly made from heavy gauge steel. Other parts precisely CNC machined; a combination of accuracy and strength. The super hard anodised finish on the finger templates ensure long term accuracy. The jig features a stabiliser bar located in front of the hard anodised comb. This provides a much greater surface area to support your router’s base. It is also where that the quick fit magnetic extraction nozzle fits.
Simple set up and use
For convenience, the UJK Universal Dovetail Jig is straightforward to set up and use. An 11mm offset at each end of the template greatly speeds up initial marking. Finally, fast cam action clamps, hold your workpieces quickly and securely.
Fantastic dust extraction
The UJK Universal Dovetail Jig incorporates an impressive dust extraction outlet. Held in place by a strong magnetic strip, the outlet is easily detached when loading workpieces in your jig.
Compatible with a range of routers
The UJK Universal Dovetail Jig lets you achieve perfect joints, every time. Very simple to use compared to the more complex jigs and at a fraction of the price, the new dovetail jig from UJK can be used with any router that will take 1/4″, 8mm or 1/2″ shank cutters.
What’s included?
The UJK Universal Dovetail Jig comes with:
- Three 1/4″ shank Axcaliber precision ground TCT router cutters; a matched pair for dovetailing (7 degree dovetail and straight) plus a 12.5mm straight cutter
- Two American style threaded guide bushes
- Router support bar
- Magnetic extraction nozzle
- Setting gauge
- 2 combs
- 3 point clamping system
- Full instructions
Important info...
Material capacity: 300mm width, 6–28mm dovetail thickness.
Don’t forget, an additional Leigh guide bush adaptor to suit your router should be purchased separately.
Discover more…
If you enjoyed reading this blog, why not check out more articles on UJK products?
Firstly, drilling straight and accurate holes freehand isn’t easy. If you want real accuracy, many people turn to a pillar drill but not everyone has the room for a floor standing or even a bench mounted model. To overcome this problem the improved UJK Drill Guide with 10mm chuck has been designed to be an accurate, portable pillar drill. Read our informative guide to discover the key features that will help you drill the perfect hole.
Next, if you want strong and hidden joints, UJKÂ Pocket Hole Jigs offer a perfect solution. Read our guide to learn more about some of the advantages of using pocket hole jigs for your woodworking projects.
Get connected!
Follow us on Instagram and Facebook to stay up to date on all the latest from Axminster Tools. Connect with us using #UJK to @AxminsterTools.
Post Updates:
Added in another benefit under the 1 jig, 6 joints heading. 'Plus, it's simple to use and easy to set up.'
