Mitred joints at the corner of a very large mirror or picture frame present some considerable difficulty when they require gluing as there may not be sufficiently large clamps available to use.  Pressure needs to be applied across the joint to pull it up tightly, but how to do it? This video shows a simple method using nothing more complicated than F clamps, sandpaper, some corner blocks and a few oddments of plywood.
guest
0 Comments
Inline Feedbacks
View all comments
