Our latest Beat The Boredom project is ideal if you’re looking to create the perfect Christmas or winter scene with the kids! Our super cute and simple slotted christmas tree will help to make your holiday moments joyful and your home a little brighter this Christmas!
What you'll need
Tools & equipment
Materials
Slotted Christmas Tree
Why not try out our super quick Christmas project? All you need is a piece of scrap plywood or MDF, and a scroll saw!
Part 1 – Mark out and cut
Firstly, draw out two small identical Christmas tree shapes; one with a star on the top and one without. Next, mark out a slot on each tree; one from the top down and one from the bottom up. This is so that the slot stops in the same position on each. Now, mark the slots and cut to the same width as the board thickness. In our example, it was 8mm.
Next, transfer the image on to the board by using some carbon paper.
Use a scroll saw to carefully cut out each of the shapes. Be sure to follow the lines as closely as you can, particularly when you cut the slots.
Once cut, check that both parts slot together nicely and sits flat at the bottom of the tree. If the slots are too tight and will not go together, lightly sand the inside of the slot until a snug fit is achieved.
Part 2 – Colour and Finish
Now’s the time to add the finishing touches to your slotted Christmas tree. With a small project like this, you could choose to use a felt tip pen to add the finishing touches. However, in our example, we opted for some green and yellow wood dye for a full and stronger coloured finish.
Win a £25 Gift Card…
For a chance of winning at £25 Axminster Gift Card, simply show us what Beat The Boredom projects you’ve completed by uploading them to Instagram, Facebook or on to our Community Forum.
Snap It
Take a photo of your project.
Tag It
Use the #BeatTheBoredom hashtag and upload it to one of the following;
- Instagram or Twitter and tag @axminstertools
- Facebook and tag @axminstertools
- The Community Forum under the Beat The Boredom post
Discover more…
If you’ve enjoyed reading this article, keep an eye out for our next woodworking project for kids as part of our Beat The Boredom series. Watch this space for more details! Furthermore, why not take a look at all of our previous projects below?
Get connected!
If you’re searching for Beat the Boredom projects, you’ll find them on the Knowledge website. Alternatively, follow us on Instagram and Facebook to stay up to date on all the latest from our Beat the Boredom series. Connect with us using #BeatTheBoredom to @AxminsterTools.
