What you'll need
Tools & equipment
Turns any matt emulsion into chalk paint!
Achieve a velvety smooth chalk or dead flat finish in any colour you choose with Polyvine’s Chalk Paint Maker. No more colour matching or using up all the tin; simply mix the formulation with ANY matt emulsion and produce a one off chalk paint! Varnished or painted surfaces rarely needs priming, making furniture renovation simple. Watch our video to see how quickly and easily you can renovate your furniture!
Upcycling furniture? Looking for a shabby chic look?
The unique formulation is great for upcycling furniture and achieving a vintage, distressed or shabby chic look. Use the chalk paint mix on wood, stone, ceramic, primed metal and primed plastic!
Preparing your mix
Using one part Chalk Paint Maker to two parts matt emulsion, thoroughly mix together. Apply the mixture to your surface using the Polyvine Chalk Brush for perfect results; designed specifically for the application of chalk paint, the brush takes a good loading to ensure the paint is evenly spread.
Don’t forget the finish!
Preserve the look of the chalk paint; Polyvine’s unique brush-on wax finish varnish maintains the velvet smooth, chalky finish of your paint, whilst protecting it from scuffing and moisture. Choose from a dead flat or satin finish.
Looking for more inspiration?
If you’ve enjoyed learning how to rejuvenate your home furniture, why not take a look at another Chair Restoration project where we show you how to restore and re-upholster an old dusty chair! Or if you’re looking to create a bespoke piece of furniture, our How To Make a Table Lamp is a great turning project for the intermediate woodturner!
