Pocket hole joinery is one of the best methods for joining any two pieces of wood where a strong joint with no visible fasteners on one surface is required. Ideal for a wide range of applications including furniture making, kitchen fitting, and edge-joining (without bar clamps), this type of joinery is also great for countertop edging, carcases and more.
Regardless of the application, if you want strong and hidden joints, UJK Technology Pocket Hole Jigs offer a perfect solution. Read our guide to learn more about some of the advantages of using pocket hole jigs for your woodworking projects.
Pocket Hole Jigs – Drill, drive, done!
If you’re into woodworking or doing projects around the home you’ll inevitably need to fasten two pieces of wood together. For the most part, there are different methods you can use to do this. However, using pocket hole jigs to produce joints is one of the most effective. It’s also a simple way of joining wood when compared to more complex joinery.
The various methods of joining wood, be it glue, nails, pocket hole joinery or other, offer advantages and disadvantages in terms of strength, speed, ease of use, skills and tool requirements. With a pocket hole, a hole is drilled at an angle that forms a ‘pocket’ for the screw to drive into.
Notably, what makes this type of joinery work so well is the design of the jig itself. A pocket hole jig guides the drill bit into the wood at a precise angle to produce a delicately engineered hole. This hole then houses the screw head. After the pocket hole is drilled, a specially designed case-hardened screw is used.
One thing is for certain, once you realise how fast, strong, and simple pocket hole joinery is, you’ll wonder how you ever got along without it. Simply drill the pocket holes, align your parts and drive the screws in!
Advantages of Pocket Hole Jigs:
- Produces strong, reliable joints with no visible fasteners on one surface. For convenience, pocket hole jigs produce clean, matching screw holes.
- There are no complicated cuts. You simply drill the pocket holes, align your parts and drive the screws home.
- The self tapping screws stay in the piece permanently and exert a tremendous amount of clamping pressure. As such, your project remains clamped solidly together.
- There’s no need to pre-drill the mating workpiece. This avoids many alignment problems caused by having to lay out and drill for aligning fasteners as with dowel, biscuit and mortice and tenon joints.
- Each joint is assembled separately so you only need to use one clamp to complete a project.
- Once you drive the screws, the joint is instantly assembled; there’s no need to wait for the glue to dry before continuing on with your woodworking project.
- Due to the all metal parts there’s no flex in the jig.
- It’s easy to assemble odd-angled parts and gives curved forms extra rigidity.
- Finally, the screws hold fast and will not split the wood, even in hardwoods.
Choosing a Pocket Hole Jig
All things considered, if you want to buy a pocket hole jig, it’s good to invest in a quality product that will deliver the results you are looking for. Offering a range of pocket hole jigs and useful accessories, UJK Technology make the art of joinery accessible to everyone. With a small amount of woodworking knowledge it is simple to achieve accurate, strong, hidden joints with a professional finish, quickly and simply.
In summary, being able to join pieces of wood together is essential when it comes to many woodworking projects. A popular yet often overlooked tool is a quality pocket hole jig. This handy tool is the perfect solution if you are seeking strong, hidden joints.
Discover more…
If you’ve enjoyed reading this article, why not check out our Insights piece focused on Pocket Hole Joinery? We’ve also got a short video with some useful Top Tips about the UJK Technology Mini Pocket Hole Jig. This video is definitely worth a watch if you want to expand your range of useful tools in your workshop.
I improved the versatility of my Pocket Hole Jig by fixing it to a bed with back support. With a base that is at the same height as the top of the PHJ base. This makes a stable frame to support the work. Allowing the work to easily slide from left to right and be clamped to the back of the frame. I have a piece of 20cm sq. 18mm MDF that I can also clamp to the back of the frame as an end stop or vertical support for battening etc. I’ve also got a couple of appropriate height out rider supports for even longer pieces of work when the jig is clamped to my larger workbench. It can either be clamped to a bench or a Workmate etc.
