Over the past few years I’ve met many people coming through the doors of the engineering room at the Axminster Skill Centre and one question has come up more than most. How do I get started in model engineering? There are not always clubs nearby and, for a novice, it can be an intimidating circle to enter. Clubs are not everyone’s cup of tea and most of us have commitments such as family, work and other hobbies that don’t allow a set amount of dedicated time each week. So, in this post I’m starting a project which can be done in a time frame you decide on.
The finished article
Starting with this entry let’s make a simple engine that will whet the appetite for discussion and further projects. The inset picture shows the finished piece and we have released drawings for those new to model engineering and a step-by-step guide on how to machine them. You will, of course, need to have a basic knowledge of machining but all is not lost if you do not. Why not come on one of our basic engineering courses and be taught by one of our engineering tutors? No experience is needed and confidence on the machine is guaranteed!
So, without further ado, let us start model engineering!
Firstly, to follow along you need some materials! Fortunately for you, we have made those used by us with the Axminster Engine Materials complete kit which you can buy here – including the basic stock to make all the parts. Alternatively, there is nothing stopping you from sourcing your own. See below for a full list of the tools we used to make our engine, all of which are available to buy now through our website.
The engine materials kit
You can download the drawings for the frame of our engine here. You will notice we have designed it to replicate the original Axminster “A”. Again this is not an essential design for the workings of the engine but, I hope you’ll agree, makes the frame both aesthetically pleasing and interesting.
Step by Step Guide
  1. Set the steel plate square on the machine bed, using engineers square
  2. Find central point of 10mm hole and measure each point from there
  3. Using a scribe, mark out points
  4. Using 6mm end mill cut all straight parts
  5. Using protractor, set work at required angle and mill
  6. Use centre drill to make pilot for 6mm and 10mm holes
  7. Drill both 10mm and 6mm holes
Tom hard at work in his shed
The tools we used to make the Axminster ‘A’:
The 'A'
The ‘A’
The next part of the project is the engine’s fly wheel. This can be as basic or as elaborate as you like. We’ve put a bit of a recess in ours and painted it red, at the very least we recommend taking the sharp edges off.
The arty shot
The arty shot
The engineer's shot
The engineer’s shot
Take a look at the drawing for the fly wheel and let us know how you get on, pictures and comments are most welcome.
Flywheel
  1. Deburr 50 x 25mm EN1A and fix into the chuck
  2. Face off material
  3. Use a straight radius tool (we ground an HSS tool) and move into the face of the material. Move the cutter side to side until you have reached the correct depth and diameter
  4. Turn work the other way and face to size and repeat process
  5. Centre drill
  6. Drill 5.5mm then drill 6mm. Alternatively, drill 5.5mm and ream 6mm
  7. Turn a 6mm mandrel and cut a thread
  8. Using a washer and a nut secure
  9. Skim the diameter taking light cuts to ensure the fly wheel does not spin
  10. For the grub screw placement; either set and drill using a pillar drill or mill. We actually used a standard pistol drill and did it by hand
  11. Tap M4 thread by hand
The flywheel
The flywheel
The next part is the fly wheel spacer or main bearing so, it is time to cut up that brass bar.
Main Bearing
  1. Put brass as close to the chuck as possible
  2. Face off
  3. Centre drill
  4. Drill and ream middle bore
  5. Turn 6.3mm long to a diameter of 10mm
  6. Part off
  7. Turn around and turn diameter with radius and chamfers
  8. Drill and countersink holes
Flywheel Bearing
Flywheel Bearing
This part concentrates on the cylinder and gets us using a four jaw chuck on the lathe. See below how we made it, if you have other ways of doing it, why not share it with us all?
Finished cylinder and cap
Cylinder
  1. Cut material to length + 2mm
  2. Put material in a the chuck on the lathe
  3. Face ends to length
  4. Mark position of the bore
  5. Hold in 4 jaw chuck
  6. Use a wobble bar to position centre of bore into spindle axis
  7. Centre drill
  8. Drill
  9. Ream – use lubrication to achieve good finish in bore
  10. Mark position of pivot spigot (ensure this is opposite to bore position)
  11. Hold in 4 jaw chuck
  12. Use wobble bar to align spigot position in spindle axis
  13. Check cylinder is 90 degrees to machine spindle (use dial gauge)
  14. Turn cylinder spigot to 6mm diameter
  15. Turn recess
  16. Centre drill
  17. Drill
  18. Tap M4
Cylinder and Barrel Pivot Pin
Cylinder Cap
  1. Hold in 3 jaw chuck
  2. Face end
  3. Turn diameter
  4. Part off to length
  5. Mark position of retaining screws
  6. Clamp cap onto cylinder and drill tapping size through both parts
  7. Drill clearance size in cap
  8. Tap Cylinder
Cylinder Cap
Cylinder Cap
The following drawings include all the shafts for the engine plus the big end, barrel pivot knob and piston.Here is the last set of drawings before assembly. These drawings include; all the shafts for the engine plus the big end, barrel pivot knob and piston. You can download the technical drawings here.
Piston and rod
  1. Face end of material
  2. Turn piston to diameter of cylinder bore + 0.02mm
  3. Turn 3mm dia to full length
  4. Cut M3 thread using die and stock supported by tailstock
  5. Part off component to length of piston
  6. Hold component on 3mm dia
  7. Hone and polish piston dia to fit the cylinder bore
  8. Correct fit should be 0.01mm clearance
Big End Eye
  2. Turn diameter
  3. Centre drill
  4. Drill 2.6mm
  5. Tap M3
  6. Turn taper to give correct length and small dia of 3.5mm
  7. Remove material from chuck
  8. Mark out position of 4mm eye bore
  9. Centre drill
  10. Drill 4mm at exactly 90° to M3 thread
  11. Replace material into lathe
  12. Part off
  13. Turn round and chamfer
Big end, barrel pivot knob and piston
Crank Web
  2. Turn outside diameter
  3. Partially part off
  4. Chamfer both corners
  5. Fully part off
  6. Mark position of crankshaft, crankpin and locking grubscrew
  7. Centre drill
  8. Drill 3.3mm for M4 crankpin and grubscrew. 6mm for crankshaft
  9. Ensure that Crankshaft and crankpin bores are both parallel
  10. Tap M4 threads
  11. Mark web angles
  12. Remove material on angles by milling or sawing and filing to size
Crank web
Crank web
Crank Pin
  2. Chamfer end 1mm x 45°
  3. Cut M4 thread x 4mm, support die with tailstock
  4. Part off to length + 1mm
  5. Turn around and face to length
  6. Turn chamfer 0.5mm x 45°
  7. Cylinder Pivot Pin
  8. Face end of material
  9. Chamfer 1mm x 45°
  10. Cut thread M4
  11. Part off or cut to length + 0.5mm
  12. Face off to length
  13. Chamfer 0.5mm x 45°
  14. Cut thread M4 to length
Crank pins
Crank pins
Cylinder Securing Nut
  2. Turn major diameter
  3. Turn minor diameter
  4. Recess with parting tool to 6mm dia forming total length of part
  5. Form knurl on maor diameter
  6. Chamfer edges of knurl and minor dia
  7. Centre drill
  8. Drill 3.3mm
  9. Tap M4 x full length
  10. Part off fully
Necessary extras, also 1x M4 grub screw is required
I’ve pictured each made component with the respective drawing, this should hopefully stop us getting into a muddle (this refers to me). You will notice on the A there is now an inlet and outlet hole for the air to go in and out of. Our outlet hole is 2mm in diameter; the diameter of the inlet hole depends on the airline fitting you choose. I’ve includes pictures of all the extras you will need to complete your engine (of course you will need a compressor to run the finished engine as well).
Download Technical Drawings
Click here to download the complete technical drawings.
guest
7 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
