Checking the fence is level How To'sHow To's section icon
Comments 10 Comments
So you’ve got your hands on a new UJK Technology Professional Router Table and have followed the instructions on how it’s assembled. To make sure you’re getting the most from the table here are some simple hints for achieving the perfect set up.
Fitting the router table insert plate
After assembling the router table you’ll need to fit the insert plate. Both of the UJK Technology 6mm aluminium or 10mm phenolic inserts offer a substantial mounting for your router. The phenolic at 10mm thick is a hard plastic that will hold its shape but is better for lighter use compared to the aluminium which is even more durable. Both of these have a blank base underneath so you will need to drill them to fit your router. There’s a centering guide template that comes with each of these that tells you how to drill it and ideally this should be in a pillar drill.
Alternatively the 10mm aluminium option is quicker to set up as it comes with a circular universal base attached to the underside of the plate. The base is pre-drilled to accommodate many different types of router and attaching them is simple and secure.
Another option is the router elevator, again underneath there is a universal base to accept different routers. Please be aware if your router fits the 10mm aluminium option it doesn’t necessarily mean it will fit the elevator. If you have any queries about this however please speak to our technical department.
The advantage of the elevator is that it allows you to adjust the height of the cutter from above the table. If you regularly change the depth of cut this is a great time saver. The elevator takes the hassle out of reaching underneath the table to adjust the router each time. So think about how you want to make adjustments and if the elevator is going to be suitable.
Keep it on the level
Once you’ve put in the insert plate you need to check that it’s level. Passing a section of timber over the plate you can see if it snags where it meets the table. If the plate does need lowering there are grub screws that adjust the level. Tighten to move up and loosen to move down. The plate should sit properly so it’s flush with the table. It’s best to check this with a straight edge as a ruler may not necessarily be totally straight. Once you’re happy with the level remember to tighten the two central bolts again. There are also bolts underneath the table which you can wind up to get everything nice and level.
Starter pin
On the insert plates are two holes either side of the central insert, here you can screw in a nylon pin. The pin is great for shape work as it acts as an infeed or outfeed pin to safely guide the work onto the cutter.
Starter pin
Does the size of the router table insert disc matter?
The router table insert discs will help to reduce the hole size which improves the extraction and also gives you greater stability across the table. It’s important to select the correct disc size. If the hole is too big the wood may catch in the hole and hit the cutter awkwardly sending wood chips flying.
Be sure to select the insert disc depending on the size of cutter you’re using. The discs are available in a variety of different sizes as well as a blank insert so you can also create your own custom hole size.
Setting the fence
One feature with the fence is a scale on the side which you can move backwards and forwards. This enables you to accurately line the fence up with the cutter plus there’s a lock knob on the side to hold it into position. Make sure the washer is on the knob to prevent wear on the slot. It doesn’t matter if the fence isn’t 100% parallel with the front of the table. As the work will centre around the cutter and the cutter is round you’ll still achieve precise results. What’s important is the cutter is removing the level of stock you want. Once you start using the t-slot at the front of the table then make sure the fence is straight.
If using a bearing guided router cutter, adjust the fence so it is align with the cutter. Using a straight edge again, run this along the fence so the outer edge of the bearing is even with the fence. If the bearing is exposed too far past the fence this will cause the wood to push out as you pass it along the fence.
Finally once the fence is in position you can move the adjustable infeed and outfeed fences closer to the cutter. This prevents tear out in the wood and reduces exposure to the bit which makes your routing safer. The fence also comes with a transparent guard that also helps to shield the cutter. When you’re happy with the position there are six knobs at the back which help to lock off the fence.
Featherboards
Featherboards add another element of safety as they help to keep your fingers safely away from the cutter. The vertical and horizontal featherboards help to apply even pressure against the fence and down on the table. They’re adjustable and you want to tighten them so the workpiece is secure but not too tight. You should be able to pass the wood through with an even pressure without pinching. Another nice feature of the featherboards is the anti kickback fingers which make working safer and more stable.
Once everything is set up correctly and you’re ready to make a pass remember to feed the wood past the cutter from right to left. In addition, as the size of the cutter you’re using changes, remember to adjust the speed. The larger the cutter the slower the speed. Using a PTFE spray will also assist with preventing corrosion as well as helping the workpiece to glide smoothly across the surface of the table.
Axminster CommunityAxminster Community social icon Community Comments
If you're looking to talk tools and machinery, why not join the conversation in our community forum? A friendly place where like minded makers and DIY'ers can exchange projects, techniques, ideas and more from the comfort of your own workshop.
  1. Thanks for the helpful tips to set up router table.
  2. I have one of those boxes set up under my UJK table. They work; sort of! It collects dust and debris but my 2hp NVD750 extractor won’t pull it out into the can. The best reason for having one is that it cuts down the router racket. When I do my routine maintenance it’s a thirty second job to clean out the box and lubricate the chain and threads on the router lift.
  3. You have a vacuum cleaner not a chip extractor on your router table, the NVD750 is ideal for dust collection from small tools, but will struggle with collecting large particles produced from a Router, what you need is a FM300BC type extractor, not a vacuum cleaner. : http://www.axminster.co.uk/axminster-hobby-series-fm300bc-extractor-filter-cartridge-package-deal-717658 this is what I have on my UJK table and it clears everything from out of the box, in fact small dogs and children are not allowed into the workshop when it is on. LOL
    There is a distinct difference between a HVLP (High volume Low Pressure) chip collector and a LVHP (Low volume High Pressure) dust collector, neither will do each others job, it will be a compromise to try.
  4. I find it a bit strange that you say you know the difference, but have complained that the dust box only works “sort of” if you used the right equipment on the dust box it would work in the way it is intended too and the box would empty as mine does, I have the Neumatic two motor 2400watt (3.2hp) unit and even that will not empty the dust box, but is good for its intended purpose, which is dust collection the fact that Axminster has put a 100mm inlet on the canister of one of their units does not mean it will work, there is just not the volume of air movement to effectively work on the large amount of chips that are produced by a Router Table.
    This may help you to truly understand the difference and why you have to have both HVLP and LVHP in the workshop: http://www.ukworkshop.co.uk/forums/a-guide-to-dust-extraction-by-member-siggy-7-t102025.html
guest
10 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
Privacy Policy & Cookies
