How To'sHow To's section icon
Comments 8 Comments
Tags
A marking gauge is one of the principal tools used to set out work. This Japanese style gauge is easy to make and use, although there is some simple metalwork involved, including silver soldering.
Degree of difficulty: Intermediate
Dimensions given are not critical.
Tool menu
You will need the following tools to complete the project:
Also needed:
  • 6mm bolt, min 75mm long, part threaded
  • 6mm nut square
  • Oak offcut approx 250 x 120 x 20mm
  • Small pieces of steel approx 1mm thick
  • HSS blank for the blade
  • 20mm square steel tube
  • Mixing container for flux
  • Butane gas torch
  • Pencil
Step 1
Prepare blank, make one end (arrowed) square.
making_a_japanese_marking_gauge_01
Step 2
Mark out position for square 6mm nut slot (45mm from square end, arrowed). Mark out position for 12mm slot, 30mm long (arrowed) and 60mm from square end.
making_a_japanese_marking_gauge_02
Step 3
Rout slot for 6mm square nut, 15mm deep.
making_a_japanese_marking_gauge_03
Step 4
Rout 12mm slot, approx 30mm long, to go completely through the oak. Waste material required underneath.
making_a_japanese_marking_gauge_04
Step 5
Mark out stock size (arrowed) 125 x 60 mm. Make sawn end square.
making_a_japanese_marking_gauge_05
Step 6
Mark the centre of the end for 6.5mm drill (arrowed).
making_a_japanese_marking_gauge_06
Step 7
Mount stock in vice in drill press, ensure stock is vertical, drill 6.5mm hole.
making_a_japanese_marking_gauge_07
Step 8
Ensure nut and bolt engage.
making_a_japanese_marking_gauge_08
Step 9
Mark out shape on stock, cut and sand.
making_a_japanese_marking_gauge_09
Step 10
Cut stem from oak offcut, leave overlong. Machine to 25 x 12mm, plane and sand to fit 12mm routed slot in stock.
making_a_japanese_marking_gauge_10
Step 11
Prepare HSS cutter, make slightly tapered (arrowed). Drill 4mm hole in stem, mark and cut 10° slot. Sharpen cutter, bevel to face towards stock.
making_a_japanese_marking_gauge_11
Step 12
Prepare pressure plate, bend at 90° around square tube. Smooth all edges to remove burrs. Note taper on each flange.
making_a_japanese_marking_gauge_12
Step 13
Prepare small rectangle for turnscrew. Cut off end of bolt (arrowed).
making_a_japanese_marking_gauge_13
Step 14
Cut shallow slot in end of bolt. Thoroughly clean all steel surfaces. Optional – glue handle blank into slot with quick setting epoxy.
making_a_japanese_marking_gauge_14
Step 15
Use water to mix Easy Flo Flux to a thick paste.
making_a_japanese_marking_gauge_15
Step 16
Insert turnscrew blank into slot, paint with flux, add 6mm long pellet of silver solder. Heat with gas torch until silver solder flows around joint. Allow to cool.
making_a_japanese_marking_gauge_16
Step 17
Clean off black oxide and finish turnscrew.
making_a_japanese_marking_gauge_17
Step 18
Cut stem to 220mm long, square cut end. Smooth all faces of stock and stem, plane off sharp edges. Tap HSS cutter into stem (1mm protrusion on reverse side). Insert pressure plate, stem and turnscrew.
making_a_japanese_marking_gauge_18
guest
8 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
Privacy Policy & Cookies
