Finished Deckchair Looking Out To Sea How To'sHow To's section icon
Beginner
Comments 22 Comments
Making your own deckchair is a great DIY project. Here are instructions for a standard sized adult deckchair.
What you'll need
Wokring Drawing
Step 1
Cut each piece to length using table saw as per drawings. Each piece should be 20mm thick
Step 2
Mark out holes with marking gauge to accept 20mm dowels as per drawing; use bradawl to mark centre
Step 3
On a pillar drill set depth to 10mm (half depth of timber). Use a 20mm forstner bit to drill all holes
Step 4
Mark out 6mm holes as per drawing
Mark out 6mm holes
Step 5
First use a 12mm forstner bit and countersink marked holes with a pillar drill to the depth of the shoulder of bit
Use a 12mm forstner bit and countersink marked holes
Step 6
Replace forstner bit with 6mm bit and drill through
Drill through with 6mm drill bit
Step 7
Using a router and router table run all pieces through beading cutter to soften edges
Step 8
Take the two medium lengths and mark out reclining slots. Three slots at 110mm, 210mm and 310mm intervals from end
Mark out reclining slots
Step 9
Using the 20mm forstner bit drill the beginnings of the slots
Drill the beginning of the slots
Step 10
Using a protractor set at 15° mark out the remaining parts of the slots
Mark out the remaining parts of the slots
Step 11
Cut out the rest of the slots using a bandsaw
Step 12
Sand back all rough edges of the slot; a bobbin sander makes this very easy
Sand back any rough edges
Step 13
Cut dowels at 2 x 450mm, 2 x 490mm and 1 x 525mm. Then finish all parts with an outdoor finishing oil
Oil parts with finishing oil
Step 14
Dry fit together making sure all parts fit correctly
Dry fit the frame together
Step 15
Assemble deckchair frame, glue the two frames and clamp together
Step 16
Using the dowel, stainless steel nuts, bolts and washers, assemble the frames together
Assemble the frame
Step 17
Lay deckchair frame flat on a workbench and cut fabric to length
Cut the fabric to length
Step 18
Using upholstery tacks attach fabric to frame
Finished deckchair
guest
22 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
