Finished deckchair On Grass Looking Out To Sea How To'sHow To's section icon
Comments 0 Comments
Making your own deckchair is a great DIY project. Here are instructions for a standard sized adult deckchair using mostly tools you’ll have in the shed.
What you'll need
Wokring Drawing
Before we start
We bought our timber machined and then ripped it down using a table saw. A good timber yard would do this for you if you supplied the cutting list. Alternatively you could use a jigsaw. If you already have machines in your workshop, why not try our machine version of How To Make A Deckchair.
Step 1
Mark out and then cut each piece to length using a crosscut saw. We used a Japanese Crosscut Saw. Each piece should be 20mm thick.
Step 2
Rip down timber pieces to size with a rip saw. We used a Japanese Rip Saw.
Ripping timber to size
Step 3
Using a hand plane clean up edges and faces of the timber.
Cleaning up the edges
Step 4
Using a crosscut saw and a bench hook trim pieces to length.
Trimming pieces to length
Top Tip!
Using a traditional push saw in conjunction with a bench hook negates the need to clamp the wood as you are always pushing the wood against the bench hook.
Step 5
Mark out holes with marking gauge to accept 20mm dowels as per drawing; use bradawl to mark centre.
Step 6
Using a power drill and a 20mm forstner bit drill all holes to half depth of the timber.
Using a forstner bit
Step 7
Mark out 6mm holes as per drawing.
Mark out 6mm holes
Step 8
First use a 12mm forstner bit and countersink marked holes with a power drill to the depth of the shoulder of bit.
Countersinking marked holes
Step 9
Replace forstner bit with 6mm bit and drill through.
Drilling through with 6mm bit
Step 10
Using a block plane soften edges of all pieces.
Step 11
Take the two medium lengths and mark out reclining slots. Three slots at 110mm, 210mm and 310mm intervals from end.
Mark out reclining slots
Step 12
Using the 20mm forstner bit drill the beginnings of the slots.
Beginning the slots
Step 13
Using a protractor set at 15° and mark out the remaining parts of the slots.
Mark out the remaining parts of the slots
Step 14
Using a fine blade Japanese saw, cut out the rest of the support notches.
Cutting support notches
Step 15
Sand back all rough edges of the slots using a piece of abrasive wrapped around a section of dowel.
Sanding all rough edges
Step 16
Cut all dowel to length with a saw and a bench hook.
Cutting dowels to length
Step 17
Cut dowels at 2 x 450mm, 2 x 490mm and 1 x 525mm. Then finish all parts with an outdoor finishing oil.
Oil parts with finishing oil
Step 18
Dry fit together making sure all parts fit correctly.
Dry fit the frame together
Step 19
Assemble deckchair frame, glue the two frames and clamp together.
Step 20
Using the dowel, stainless steel nuts, bolts and washers, assemble the frames together.
Assemble the frame
Step 21
Lay deckchair frame flat on a workbench and cut fabric to length.
Cut the fabric to length
Step 22
Using upholstery tacks attach fabric to frame.
Finished deckchair
guest
0 Comments
Inline Feedbacks
View all comments
