Produce highly accurate and strong cabinets and joinery items simply and quickly with the new Festool DOMINO DF 500 connector set. The new basic structure and furniture connectors are extremely versatile and provide for a very large range of applications. Ideal for use in the workshop, at home or on site, Festool’s new DF 500 connector set achieves first class results more quickly than ever before.
Festool DOMINO DF 500 Connector Set KV-SYS D8
If you want to create perfect timber connections quickly and efficiently choose Festool’s new DF 500 connector set. The new Festool DOMINO connector range KV-SYS D8 contains a mixture of basic structure connectors and furniture connectors. These are designed for use with the DOMINO DF 500 joining machine. The connectors enable stable yet flexible furniture designs that can be assembled, disassembled and reassembled in another location as well as shelving and much more.
InsightsInsights section icon
Features and Benefits
Complete tasks independently
Tasks which may have required two people before, can now be completed alone. This makes the new Festool connector set fantastic for cupboard/ wardrobe assembly, for example. The connectors’ long bolts and large tightening distance also makes furniture assembly significantly easier for knock down (KD) construction.
Create flexible designs with ease
Due to its high stability and high tolerance compensation, the detachable DOMINO joining system enables fast, hassle free assembly and disassembly of furniture and structures. Perfect for when you are in the workshop, or onsite.
Work quickly and efficiently, wherever you are
All joints are simple to position and machine using the DOMINO DF 500 joining machine. This means that if needed, the full range of accessories can be utilised, saving you time and effort throughout the process.
Extremely versatile
The DOMINO DF 500 connector set is very versatile. The connectors are ideal for centre panel joints, corner panel joints and joints between a series of holes. This makes the detachable DOMINO basic structure connectors and furniture connectors perfectly suited for a panel thickness of 18 mm to 28 mm.
Error free work
Using the drilling guide, it is possible to specify the exact position of drilled holes. It is also possible to ensure the correct drilling depth for complete accuracy and control. It is now simple to produce a detachable corner joint without much effort. Corner joints require two DOMINO holes and a drilled hole for quick connection without additional measurement. Centre panel joints require two DOMINO holes and a through hole. Please note: Use the drilling guide with suitable dust extraction.
Flush-screwed fixture elements
The covers protect each furniture component against scratches. Furthermore, routing and cutting tolerances of up to 0.7 mm are compensated for without problems by the fixture.
One great value package
Ideal for first-time users, the new connector set contains all necessary DOMINO D8 connectors, the associated drilling guide and the cover caps in four different colours. This handy set provides fantastic value for money.
A complete system
For flexibility, the new DOMINO basic structure connectors and furniture connectors can be positioned simply and easily. This can be achieved in combination with a DOMINO DF 500 joining machine. Each connector utilises a DOMINO hole for installation – and later for removal and re-assembly elsewhere.
Contents
The new Festool DOMINO DF 500 connector set KV-SYS D8 is supplied in a SYS 1 T-LOC Systainer and contains:
  • 70 x Domino/Domino KV D8 basic structure connector
  • 20 x Domino/LR32 KV-LR32 D8 basic structure connector
  • 10 x Domino/Domino MSV D8 centre panel connector
  • 10 x Domino/LR32 MSV-LR32 D8 centre panel connector
  • 20 x Domino D 8 x 36 mm
  • 1 x BS-KV D15 drill template (Festool ref: 203164)
  • 1 x KVB-HW D15 CE hinge location cutter (Festool ref: 203165)
  • 50 x dark brown cover caps, 50 x silver cover caps, 50 x white cover caps, 50 x grey cover caps
  • 1 x screwdriver
Festool Domino
Join the Festool Connector Revolution
In addition to the new Festool DOMINO DF 500 connector range KV-SYS D8, there’s also a wide range of accessories suited to the Festool DOMINO joining machine.
Discover more…
If you are a Festool fan, our ‘First Look’ at the Festool Hybrid Sanders is definitely worth a read. With some clever new innovations to help you in your work it’s now possible to easily switch between a corded or cordless sander. Alternatively, why not take a look at our piece on Festool Mobile Dust Extractors? Extraction is an essential part of any workshop. When it comes to your health, reducing dust is a priority. The latest updates from Festool mean you’ll achieve more success even more quickly and easily.
Finally, there’s the new Festool ISC240Li 5.2 EBI SET FS Insulation Saw 18V (5.2Ah) available to order now. Designed for professionals installing insulation, the Festool ISC240 saw allows you to cut insulation efficiently with minimal effort. The time saving is immense and waste cut to a minimum.
Get in touch!
If you’ve bought Festool’s new DF 500 connector set, we’d love to hear from you. Comment below or send us a photograph and tell us all about your new purchase. What do you love about the connector set, and why?
Alternatively, get in touch via our social media platforms. Find us on Facebook or send us a tweet using #festoolconnectors to @AxminsterTools.
guest
0 Comments
Inline Feedbacks
View all comments
