Sausage Dog Crayon Holder
The perfect decor item for a child's bedroom, or as a gift for pet lovers, this wooden Sausage Dog Crayon Holder is handcrafted from start to finish. Designed for younger children under adult supervision, our latest Beat The Boredom 'How To' is a great woodworking project to try!
Part 1 - Mark out
Cut out your template with a pair of scissors. Next, draw around the shape onto your selected piece of timber. The body of the Sausage Dog onto the 20-25mm thick piece, the feet and ears onto the 3mm piece.
Part 2 - Cut out
Set the height of the hold down foot and guarding just above the workpiece. Carefully cut around the outline of the body, but do not forget the mouth detail. Reset the hold down foot for the thinner material. Next, cut the Sausage Dog ears and feet (paws). Here, we left our piece oversized so it was easier to hold when we cut the small components.
Part 3 - Mark up and drill
Measure the thickness of the dog’s body and mark a centre line along the length. Next, add some marks with a 20mm spacing - these will be where you drill the holes for the crayons to sit in. In our example, we used a 10mm lip and spur type drill bit for accuracy. Set the depth on the pillar drill. Finally, swap the 10mm for a 3mm drill bit to drill the eyes.
Part 4 - Sand and glue up
Soften the edges with a piece of abrasive on both the body and the ears and feet. Remove any pencil marks left behind. Apply a spot of glue to the inside face of each ear. Position and clamp the ears to the head. Do the same with the feet; add a small spot of glue on each before you place the body of the Sausage Dog on top. As it is a difficult shape to clamp, we suggest that you use a bottle of glue to weigh it down, as we did.
Part 5 - Pin the feet and finish
After approximately 30 minutes, gently tap a small panel pin through the bottom of each foot into the legs. Your Sausage Dog Crayon Holder project is nearly complete. To finish, add a food safe oil to the timber, but feel free to paint and decorate your project however you like!
See the plans
Win a £25 Gift Card…
For a chance of winning at £25 Axminster Gift Card, simply show us what Beat The Boredom projects you’ve completed by uploading them to Instagram, Facebook or on to our Community Forum.
Snap It
Take a photo of your project.
Tag It
Use the #BeatTheBoredom hashtag and upload it to one of the following;
Discover more…
If you’ve enjoyed reading this article, keep an eye out for our next woodworking project for kids as part of our Beat The Boredom series. Watch this space for more details! Furthermore, why not take a look at all of our previous projects below?
Get connected!
Follow us on Instagram and Facebook to stay up to date on all the latest from our Beat the Boredom series. Connect with us using #BeatTheBoredom to @AxminsterTools.
