Give a man a FISCH and you feed him for a day. Teach a man to FISCH and you feed him for a lifetime. Well now you can do both. Enter our competition to win free FISCH bits and you can feed your chuck and drill perfect holes for a lifetime.
The following FISCH bits are up for grabs, worth over £110…
25 Piece HSS Brad Point Drill SetExtremely resistant with a ground centre point and spurs for precise positioning and a clean cut. |
Quick Change System Forstner Bit – 25mmProduce clean, accurate and flat bottomed holes. |
Quick Change System Plug Cutter – 6mmA plug cutter designed for cordless and hand drills with a universal quick change shank that will fit any system including Festool’s Centrotec. |
Quick Change System Auger Bit – 10mmGround from one piece for strength, with a clean and quick cutting action. |
