Bosch Brushless 18V Combi Drills Buying GuidesBuying Guides section icon
When it comes to Bosch combi drills, brushless rules! With a newly updated range of 18V brushless combi drills, Bosch offer a three tier performance range of tools for every user. Simply select the performance level you require and start working more flexibly, all without losing brushless efficiency.
Brushless Technology
Traditional DC tool motors contain brushes that are continuously worn down when in use. These need to be regularly replaced in order for the tool to perform at peak efficiently. Furthermore, when these brushes wear it causes resistance and heat. As brushless motors do not contain brushes, they are maintenance free. They are also significantly more efficient and powerful, resulting in a tool that has up to 100 % longer lifetime and 30% longer runtime per battery charge.
Bosch Combi Drills – 3 Tier Performance Range
The GSB range of Bosch combi drills are intended for driving in and loosening screws. They are also great for drilling in wood, plastic, metal and ceramic. Furthermore, they’re ideal if you need to carry out impact drilling in bricks, brickwork and masonry. For convenience, the combi drills are fitted with a light to illuminate the area you are working. With the Bluetooth Low Energy Module GCY 30-4 inserted, settings and data of the drill can be transferred between the power tool and a mobile terminal device via Bluetooth wireless technology.
Entry Level
The Bosch GSB 18V-55 is a fantastic entry level Brushless 18V Professional combi drill. When you want brushless performance and efficiency without needing the Connectivity function, this combi ticks all the boxes. It’ll do 90% of what the average tradesperson would need in their day to day work. Buy your Bosch GSB18V-55 Combi Drill 18V (3 x 3.0Ah) today.
Mid Range
Next, the Bosch GSB 18V-60C is a mid range option and features Connectivity as well as KickBack Control. If you’re a tradesperson who uses a combi drill each and every day, this is a fantastic option. Trust in Bosch professional tools; buy your Bosch GSB 18V-60 C Brushless Combi Drill in L-Boxx (Body Only) now direct from our website.
Heavy Duty
Finally, the Bosch GSB 18V-110 C is a heavy duty, flag ship brushless combi drill. The GSB 18V-110 C is one of Bosch’s connectivity tools, with the capability to control various options and features within the tool through your smartphone.  It also features excellent KickBack Control. It’ll pack a punch in a variety of applications and will save you time, money and effort as you work. If you use a combi drill day in, day out, this is the perfect choice! Purchase the Bosch GSB18V-110C Brushless Combi Drill 18V (2 x 5.0AH) via our website. Any questions? Speak to us for more details.
Discover more…
Did you enjoy this article? Why not read some of our latest articles including how to choose the perfect Bosch battery to suit your needs. This includes the latest ProCORE18V range of high performance batteries. Alternatively, why not find out more about Starlock by Bosch with another of our helpful guides. Starlock, a joint venture between Bosch and FEIN, is a patented blade mounting system that provides a very fast ‘snap in’ blade fitting. In recent years, the Starlock system has set the new standard for multi-tools and accessories.
Next, learn about the Bosch GCM 18V-216 BITURBO Mitre Saw. Ideal for a wide variety of applications, the mitre saw is a fantastic choice wherever you are working. With comparable power of an 1600 watt corded machine, the BITURBO tool has been specifically designed and optimised to work with the Bosch ProCORE18V battery platform.
Want to see the tools before you buy? If so, pop into any of our Axminster stores to see our power tool selection from Bosch as well as other leading power tool suppliers.
Get in touch!
If you’ve bought the any of the above Bosch combi drills, we’d love to hear from you. Comment below or send us a photograph and tell us all about your purchase. Alternatively, get in touch via our social media platforms. Find us on Facebook or connect with us on Instagram using #boschcombidrills to @AxminsterTools.
guest
0 Comments
Inline Feedbacks
View all comments
