Best of Bosch 2021 at Axminster Tools
Whether you prefer 18V or corded tools, Bosch have plenty of options for you. In this blog we, at Axminster Tools, explore some of the best new Bosch tools from 2021 so far.
Bosch GCM18V-305 Mitre Saw 305mm 18V (Body Only)
This is an extremely powerful saw thanks to the BITURBO Brushless Motor and, especially when paired with Bosch Procore batteries (turn to eco mode and run time increases by 30%!), it is just as strong as the Bosch corded mitre saws. The GCM18V-305 also incorporates the ‘Axial-Glide’â„¢ system which ensures smooth and accurate cuts, every time. Featuring a sliding function for large workpieces and a double bevel allowing angled cuts up to 47 degrees, this saw is versatile and easily transportable making it perfect for home workshop or professional use. Supplied as a body only tool, batteries and charger not included.
Bosch GSB12V-15/GDR 12V Combi & Impact Kit
Don’t let the 12V fool you with these two tools. Despite the lower voltage, both perform at a professional grade level, offering power coupled with compact and lightweight feel. The GSB 12V-15 Combi Drill features a two speed gearbox and 10 torque settings and can be used for drilling wood, metal and masonry. There is also a handy LED light to help with visibility. The GDR 12V-105 can deliver up to 105Nm of torque and also features a LED work light. Together these 12V tools are the perfect combination.
Excellence from Bosch
Bosch GBH18V-21 Brushless SDS+ Drill in L-Boxx (Body Only)
Featuring yet another Bosch maintenance free, brushless motor giving your tool improved battery run time, the GBH18V-21 provides 2.0 joules of impact energy for professional performance. There are three functions for maximum versatility; rotary drilling in wood or metal, hammer drilling in masonry or hammer only for chiseling. A variable speed ensures control, whilst the Rotation Control Clutch ensures safety. It is supplied as a body only tool and is compatible with all Bosch Li-ion batteries.
Bosch GEX 40-150 Random Orbit Sander in L-BOXX – 230V
A corded random orbit sander, this is a professional, high performance tool with low vibration thanks to the integrated vibration dampening. The main feature setting this sander apart from the rest is the 150mm sanding pad, which has a multi hole design, allowing you to use any brand of abrasive, as well as significantly increasing the extraction efficiency. These two combined ensure a great surface finish and extend the life of your abrasive. The GEX 40-150 can be used for sanding, polishing, finishing and lacquer removal.
Powerful sander with great dust extraction
Bosch GAS 35 H AFC Wet & Dry Extractor H Class 230V
Bosch’s first H class extractor, the GAS 35 H AFC traps 99.995% of hazardous waste, including carcinogenic and pathogenic dust, and this refers to the whole machine, not just the filters. Air flow is regulated by the control monitoring through the suction cup and there is an acoustic warning signal which sounds if the air flow gets too low. The extractor is automatically engaged when your power tool turns on due to the auto switch socket. Compatible with all Bosch Click & Clean power tools, the GAS 35 H AFC ensures dramatically increased user protection, which is just what everyone is looking for.
Bosch GSB12V-35 Brushless Combi 12V (Body Only)
This combi drill offers the highest impact rate in the 12V series and, with a top speed of 1,750rpm, you will not be left wanting for power or performance. The GSB12V-35 is compact and lightweight, allowing you to use it anywhere and features a convenient LED light and belt clip. The Bosch Electronic Cell Protection ensures your battery will not overload or overheat and it can be utilised for drilling, impact drilling and screwdriving. A great combi drill all round! Supplied as a body only tool without batteries or charger.
Learn more about Bosch
3 year guarantee, the Toolbox app and more – click here…
Get in touch!
If you’ve bought any of the above Bosch tools, we’d love to hear from you. Comment below or send us a photograph and tell us all about your purchase. Alternatively, get in touch via our social media platforms. Find us on Facebook or connect with us on Instagram using #boschtools to @AxminsterTools.
