Cyclone dust extractors have become popular with professional workshops because of their unique blend of performance and capabilities. Designed with the home user in mind, Axminster Craft offers three cyclone extractor models, which will efficiently capture the dust created by most woodworking machines.
Cyclone extraction for your home workshop
How cyclone dust extractors work
Often referred to as a two-stage dust collector and unlike traditional dust collectors, cyclone dust extractors have two collection points for dust and debris. The first collection point is for the larger chips such as planer debris, whilst the second collection point collects the very fine dust, typically generated when sanding.
The system works by first drawing the wood waste into the air stream through the dust ports. Once the air enters the machine, the negative air creates cyclonic (centrifugal) action, causing the air to spin around in the cyclone housing.
Large, heavy wood chips fall down the housing into the first container, while the lighter dust particles are drawn up through the impeller into a filter canister. Any remaining fine dusts are collected in the second compartment.
Cyclone Extractor Diagram
Benefits of a cyclone
Keep dusts at bay
The cyclone technology reduces dusts entering the filter and therefore minimises the airborne dusts escaping from the machine. Not only does this improve the air quality in your workshop but it also helps to keep your workshop dust free.
Eliminate any damage
As the air stream is drawn in below the impeller, any large pieces of wood will drop down into the first compartment. Therefore eliminating any damage which can be caused by it hitting the impeller.
Efficient extraction and a longer life
By separating the wood waste and collecting the large wood chips before they enter the filter cartridge, this prevents any build-up of debris in the filter. Enabling the machine to carry on working efficiently for longer.
AC118CE Cyclone Dust Extractor
Three models to choose from
Designed with the home user in mind, our Axminster Craft Cyclone Extractors are available as three different models.
The AC118CE Cyclone Dust Extractor offers you the complete dust extraction system. Designed for the home user but boasting qualities found within professional cyclone machines, the AC118E gives you clean and very efficient dust extraction.
Fitted with twin dust ports, you’re able to choose between twin 100mm or a single 125mm inlet. Its sturdy tubular steel frame holds the main body securely. Whilst the castor wheels make this machine easy to move around in your home workshop. The extractor is powered by a 1.5kW (2hp) motor, which provides plenty of power but runs happily on a domestic 13A supply.
Plus, fitted with a handy filter cartridge handle, you’re able to easily clean the cartridge of any excess debris. Allowing the machine to carry on working efficiently without a build-up of dust in the filter.
AC118CI Cyclone Interceptor
The AC118CI Cyclone Interceptor allows you to upgrade your current chip extraction system or create a wood dust and chip extractor which will handle even fine dusts from drum sanders.
Unpowered, it includes a cyclone interceptor and waste bin.
Use with a standard High Volume Low Pressure chip extractor to provide the airflow. Fitted with 102mm inlet and outlets, it suits many common home woodworking machines. The waste bin is a generous 118L, whilst the casters allow for easy mobility around your workshop.
ACCIH Cyclone Interceptor Head
Already popular with many of our customers, the Interceptor head enables you to create efficient dust extraction for your workshop. Supplied as the head only, you can make your own suitable dust container and position the unit to where you need it; whether it’s mounted on the wall as part of your dust extraction system or placed next to your drum sander.
Need help?
If you need help or advice on Axminster Craft’s Cyclone Dust Extractors or extraction for your home workshop, get in touch with one of our Axminster Experts. Simply pop into your local Axminster store and chat with our experienced sales advisors, or call our dedicated Customer Services team for advice. Alternatively, talk to us through our Online Chat function on our main website. As always, you can get in touch and ask questions via any of our social media platforms. We are here to help you!
InsightsInsights section icon
Discover more!
We hope you’ve enjoyed learning about the Craft Cyclone Dust Extractors. If you’re still unsure about which dust extraction is right for your workshop, then why not read this helpful Buying Guide on dust extraction. Or, if you’re new to woodworking and you’re discovering Axminster Craft for the first time, why not take a look at this helpful Insight to learn more about the range.
guest
0 Comments
Inline Feedbacks
View all comments
