If you’re on the lookout for a table saw to help you achieve your woodworking ambitions, look no further. The powerful Axminster Craft AC254TS Table Saw brings the cutting capacity of a trade workshop into the home workshop, making it ideal for many types of crafts and DIY projects. Read our short article about why this table saw could be the best solution for you.
Great for most woodworking projects, this table saw is ideal for sizing up wood before you join it together or plane it, prior to the sanding or finishing stage.
Featured In This Article...
“…Excellent piece of kit..I can highly recommend the AC254TS table saw and Axminster service.”
Walron, Axminster customer
Features and Benefits
Fantastic cutting capacity
Enjoy large, accurate and fast cutting 80mm capacity with this table saw; a real workhorse of any home workshop.
Stable and robust
The ground cast iron table allows your workpiece to run smoothly across the table. The rigid rip fence offers maximum support while you work.
Achieve multiple cuts
The table saw allows you to achieve a range of different cuts. These include all manner of straight cuts, mitred cuts and bevel cuts.
Ideal for a range of materials
Need to cut man made materials such as ply, MDF or sheet materials? Or natural timbers including hardwood and softwood? If so, this table saw is just the ticket!
Highly efficient dust extraction
With extraction from both above and below this table saw is ideal for small workshops. It helps your work area to stay clean and also helps to reduce the amount of dust in your environment.
Important safety feature
An NVR switch with separate locking Emergency Stop function helps to safeguard your health at all times.
Easy maintenance
The table saw features removable side panels for easy cleaning and maintenance.
Super smooth tilt and height adjustment
Super-tune your table saw for absolutely straight, smooth and burn-free cuts.
Optional Accessories
With these optional accessories, the Axminster Craft AC254TS Table Saw becomes a truly exceptional machine.
Convert into a floor standing table saw
Offers a generous length of travel past the blade
Puts your saw table at a comfortable working height
Provides vital support, when working with sheet material
Just want the AC254TS Table Saw for now?
Discover more…
Why not explore Woodworking Wisdom, your one-stop woodworking video destination. Live sessions every week, including; tutorials, product videos, unboxings, special guests, Q&A’s, projects, and so much more! Simply subscribe to our YouTube channel to stay up to date on all our latest videos!
Get connected!
Follow us on Instagram and Facebook to stay up to date on our latest tools and machinery. Connect with us using #AC254TS to @AxminsterTools.
