InsightsInsights section icon
Comments 0 Comments
Most users of any sort of workshop will want to spend their time in it as effectively as possible. In an efficient workshop, projects become easier and quicker to make with a dividend of better working conditions and enhanced Health & Safety aspects. Here are our 10 top tips which might make the difference between working in tranquil calm or complete bedlam!
dusty_bandsaw_blade
1. Workshop Dust – a menace
Very recently, there’s been a series of entertaining programmes on Channel Four about sheds. Some of the builder’s creations have been imaginative masterpieces, from a camper van to a Polish mountain drinking den. But the majority of people who own a shed will probably have them for storage, gardening or as a workshop.
pt_with_extraction
It may be likely that the shed is going to be used for woodworking activity and if it is, then perhaps the most important area is the issue of wood dust. Health & Safety concerns, of which dust is a part, are of paramount importance. Many common timbers are toxic to a greater or lesser extent, but as will be seen from the information provided by the HSE, a considerable number can also be used regularly without encountering problems.
extraction_system
Some time ago on The Knowledge, there was an Axminster Buying Guide which went some way to summarise the menace of dust. A more chilling, graphic illustration appeared in this article which showed the effects of planing and routing for three days.
Professional users are no less immune to the effects of wood dust, but are probably in a working environment where the dangers and solutions are understood. Whether or not you’re a trade or hobby woodworker, dust and debris will always be the number one enemy. Fortunately, Axminster Tools has an array of equipment to suit either a weekend hobbyist or professional cabinet maker. Whatever’s needed to combat the dust menace, find it here at Axminster.
buying_a_lathe05
2. Personal Protective Equipment (PPE)
Apart from the purchase of dedicated dust extraction equipment, the hobbyist or professional woodworker should also pay attention to PPE. Brief mention of dust masks has already been alluded to, but the Axminster full range can be found on our Respiratory Protection & Facemasks page. One item is the recently introduced APF 10 Evolution Powered Respirator. If ‘The Force’ is with you, or even if you’ve been left way behind on the starting blocks, it’s worth spending a few moments to read our full review of this excellent piece of kit.
hat_mounted
Face masks and respirators are not the whole story when it comes to PPE. There are other factors that need to be taken into consideration which are very much task dependent. The full range, including head, hand, eye and hearing protection, as well as other areas which may not be quite so obvious, can be found on this page. Before starting any practical work, it’s essential to think about proper eye protection, gloves, or even perhaps a hard hat, which may potentially keep you out of A&E!
workshop
3. A Tidy Workshop
One of the most important factors to improve efficiency is to ensure that the workplace is relatively clean and tidy. This is not to say that it should be dusted daily to a level of pristine perfection. But unnecessary clutter, jigs, fixtures, piles of scrap and oddments should be disposed of from time to time. Removal of unwanted workshop detritus has the effect of releasing space, which can then be used to much greater advantage.
clamp_storage
There are other strategies that can also be used to improve the overall efficiency. Examples include retractable air lines or electrical power blocks that drop down to bench height from the ceiling. These types of products also negate the very obvious H&S risks of trailing cables and air lines. Clamp storage can also be improved, as most workshops soon end up with a huge assortment and a movable rack might be beneficial. Where there’s adequate space, sash and G clamps can be wall mounted using the appropriate rack.
Bundles-of-veneer-stored-over-the-workshop-window
Timber storage is always a problem too. But if it’s racked out securely it has the added benefit of much easier access, as well as reducing the footprint in the workshop. Man-made boards will deform and bend under their own weight and should be stored vertically or horizontally in a purpose built rack. A thick 8×4’ sheet of mdf is extremely heavy to manhandle around the workshop. If they’re lifted on a daily basis, a Roughneck Gripper will prove invaluable. Mundane though it may appear, regular use of the humble dustpan and brush or vacuum extractor also helps to keep the workshop looking ship shape.
isolated_lighting
4. Lighting
Adequate lighting in the workplace is essential and goes a very long way to improving efficiency. In most workshops, natural daylight is enhanced indoors by overhead lighting, usually provided by fluorescent strip tubes. These provide a good level of background lighting. Quite often there’s a need for more localised illumination, perhaps for use on a bandsaw table or a maybe a portable work light to shine into a dark cupboard. Brighten up your day by viewing Axminster’s complete selection of lights!
workshop_floor
5. Flooring
There’s no getting away from it, concrete is hard stuff and even harder on the legs. Especially when you’ve had to do a full eight hours in the workshop! Unfortunately, most professional workshops are in buildings or units where the floor is concrete, which is ideal for supporting heavy machinery, but not the soles of your feet.
There are several ways to improve the situation, one of which is to lay a separate wooden floor on top. This, however, is time consuming and expensive. The other option is to wear a pair of safety work boots that have cushioned soles. They have the added advantage that the steel toe cap prevents damage to your feet should anything untoward fall on the boot. The final method is to lay anti-fatigue matting in areas of high footfall. These 10mm thick interlocking rubber tiles provide a cushioned surface and so help to reduce the stress of standing for long periods on a hard surface.
717767_inset2_joined
6. Sharpening Systems
The American woodworker and author Chris Schwarz once said that “sharp fixes everything”. And there has never been a truer statement in a workshop. Sharp does fix everything. But what do you use to get tools sharp?
There are dozens of different ways to sharpen tools and every craftsman or woman will have their own particular method. It may be no better or worse than an alternative system, but it works for them.
tormek_t-8
Of all the many ways to sharpen tools, one of the most popular is the Tormek T-8 Sharpening System. This system offers the ability to repeat the correct grinding angles every time it’s used. As the wheel runs in a water bath, there’s no danger of overheating the steel. In addition, there’s a large range of accessories for the machine(s) which will enable a very sharp edge  on almost any hand tool.
Should the wood or metalworker prefer a dry running bench grinder, we have a very comprehensive selection. Many of which can be used with accessories to make the sharpening process easier.
At the bench, there a number of sharpening systems, all of which can be used freehand or with a guide which guarantees that the honing angle can be repeated each time. The principal systems are the traditional Oilstones, Japanese Waterstones and diamond sharpening stones, each of which produce excellent results.
When circular saw blades become a little ‘tired’ after sustained use, all Axminster stores offer a competitive re-sharpening service, guaranteed to restore your treasured blades to ‘as new’ condition.
screws
7. Consumables
Any workshop, be it hobbyist or trade, will usually need a fairly constant supply of consumables to work effectively. The lack of a particular item may not be of immediate concern to the hobbyist, but may be of critical importance to the professional, where constraints of time and money are always at the forefront. Items such as sandpaper, bandsaw blades, table saw blades, batteries, spindle moulder tooling, router cutters, glue, polish, nuts and bolts, nails, screws and other innumerable items all have their place in the pecking order. Each assumes its own priority depending on stock available in the workshop and the importance of it relative to the job. Run out of 30 x 5mm Torx screws or even a spare T20 bit to drive them and the job which should have been completed on Tuesday afternoon will now be delivered to the customer on Thursday!
buying_guides_gloves_inset_01
8. Machinery Maintenance
Unless you work entirely by hand, you’re bound to have some sort of machinery. This is especially pertinent in a professional trade workshop, where time is money. Apart from those considerations, using machinery generally means that work produced is far more accurate than it otherwise might be. Whatever machines are used at some point they’re going to need routine preventative maintenance. This may be no more than minor adjustments to belts or guides, cleaning out sawdust or the application of lubricant. A broken machine in a professional workshop is likely to be very expensive in ‘downtime’.
Spray with Axcaliber Dry Lubricant
For most woodworking machinery a dry PTFE spray is the ideal lubricant. But we stock a complete range suitable for almost every conceivable application.
axminster_machine_wax
To protect and lubricate cast iron surfaces against possible surface rust in less favourable working conditions, a coating of Axminster Machine Wax is excellent. Should you be unlucky enough to experience the blight of a dreaded rust spot on your precious machinery or hand tools, Garriflex Blocks are also equally good at removing it. In addition, we also stock a very good range of products specifically intended to clean and protect all vulnerable materials from corrosion.
1.-60W-spot-lights
9. Workshop Benches
A bench is an essential part of almost any workshop, as it’s the place where components are made and projects assembled. The workbench is a pretty simple affair, nothing more than a flat, stable surface. And for many hobbies, an ordinary table top is perfectly adequate. It’s only when a more demanding task is attempted, such as planing timber, does the limit of the kitchen table become obvious. It soon becomes apparent that a much stronger, more rigid structure is required, which will resist the forces acting on it, which if unchecked would soon tear the kitchen table apart. The workbench also has the advantage of acting as a clamping surface, as it’s very easy to fit a vice and other types of clamping devices to make holding and assembling components much easier.
workbench
Benches for the weekend hobbyist are light duty as they’re not expected to ne used heavily. But increasing commitment to woodworking in any of its forms may require something a little more robust. At Axminster, we supply a very comprehensive range of heavy and very heavy duty benches. Choosing a heavy duty workbench is no light undertaking and we have recently published a guide outlining the desirable features.
ujk_technology_table
Working with sheet or board material has always been problematic, owing to the larger dimensions. Especially when there’s a need to cut it accurately at 90° and holding it securely on a conventional bench is difficult. The recently introduced system of UJK Technology Multifunction Benches provides users with a superb and highly accurate way of cutting ply and mdf. With a little adaptability these benches may also offer a completely unique and new way of working. A bench is one of the core pieces of equipment that every woodworker needs. Time, care and consideration should be taken before one is purchased. Like all tools, it pays to buy once and buy the very best.
mobile_base
10. The Mobile Workshop
Workshops tend to be filled with heavy machinery, benches as well as heavy timber. Anything that makes life a little easier in moving it is to be welcomed. This will also add to the efficiency of the workshop.
In a big workshop, machinery is usually large, extremely heavy and is positioned so all can use it. Casually moving around a panel saw weighing close to 600kg isn’t really any sort of practical proposition. And machines of this nature are permanently connected to a steel dust extraction system.
mobile_workshop
More compact machinery such as our Trade Series AT107PT Planer Thicknesser has the option of being positioned on a mobile base resulting in a more manageable arrangement in the smaller workshop. And when mounted, it should have a flexible dust extraction hose to allow freedom of movement.
Being able to reposition machinery is a great help. But it’s also advantageous to be able to move heavy boards and part completed projects around the workshop. In this instance, trucks and trolleys are invaluable. They are a great asset in moving material and equipment around, and there’s also less chance of an accident.
custom_mobile_base
Where circumstances allow, it’s also possible for the tradesman or hobbyist to make their own custom-made trolleys or tables using our extensive range of wheels and castors.
The final item, which without doubt increases efficiency in ‘the mobile workshop’, is a roller stand which can usually be found on the ‘out feed’ side of a planer thicknesser, table saw or bandsaw. It can be positioned to support any long or heavy piece when it’s difficult to hold.
Conclusion
The strategies outlined here ought to provide a useful framework for the organisation of the workshop. Whilst everyone works in a very different way, an efficient workshop is a goal to strive for. It provides more satisfying conditions in which to make your projects.
guest
0 Comments
Inline Feedbacks
View all comments
